1998 115 timing
jeremy5780
I cannot get my timing set on my 115 rude. The book i have (seloc manual) is very vage in this subject can anyone point me in the right direction IE a better maunual or something on the forum that goes into more detail? I am looking for some help other than just keep playing with it until you get it!!!
HighTrim
Re: 1998 115 timing
Another reason why the Seloc is only good for soaking up spilt oil. ;)
I would highly reccomend you invest in a factory OEM Service Manual. Will pay for itself a million times over. Check ebay or www.outboardbooks.com for a factory reprint.
http://cgi.ebay.com/ebaymotors/1998...50068272675QQptZMotorsQ5fManualsQ5fLiterature
Check the FAQ's here on iboats for a thread by Joe Reeves regarding the timing. Actually, here it is here
http://forums.iboats.com/showthread.php?t=228183
Dhadley
Re: 1998 115 timing
Which 1998 115 do you have? Explain what you mean by "I cannot get my timing set". What have you done so far that's not coming out right?
jeremy5780
Re: 1998 115 timing
It wont start so i disconnected the throttle at the motor. If i advance the spark a little it will start and run rough then stall out if i do get it ideling smootht when i go to give it a little gas it bogs down and stalls then i must start all over again. iam just trying to get all the adjustments set where they need to be.
James R
Re: 1998 115 timing
The Seloc manuals and the Clymer are very similar. The Clymer manual that I have in my library gives clear and concise Syncronization set up instructions.
Try looking in that section of your manual. Follow the procedure carefully.
