1998 120 force bogs under load
aqua twinz
my boat sat for two years before realizing this problem i changed the gas, fuel filter and diaghram fuel pump, the marina cleaned my carbs and adjusted the idle and chaged the starter.the motor at idle runs fine but in gear i cant get her past 3000rpms. marina suggests a bad stater ,all 4 plugs have a good spark the motor does not have that many hours and has always ran great.i did try to use the merqury carb cleaner before doing any of this work whle the boat was on the trailer with flush hooked up didnt realize that was not the directions then let it sit for a month. plese help for the bass will soon be blitzin
roscoe
Re: 1998 120 force bogs under load
I agree that it is likely a stator issue.
They (marina) can test the stator, which should only take them a few minutes, and is 90% at diagnosing the stator.
FYI - the stator is divided into sections, each section generates current for a specific use. It appears the section dedicated to high engine rpm, has failed.
craigf
Okay my maxum with a 120 force is bogging also I got the manual did what it said to test the stator the results are green/white to white .733 on ohm 2k on the yellow to yellow it is nothing. one of the yellow conectrs looks like it melted and is black it also metled the other yellow not as bad and the red wire to the rectifier the rectifier black to yellow was 9.56 on both the black to yellow and grey to yellow were nothing
Were should I go from here?
foodfisher
Craigf, What you are doing is called thread jacking. If we answer your ?'s the thread starter (aquatwinz) will not get his ?'s answered. Politeness requires you to start your own thread.
craigf
Well this was an old post sorry I thought that it was better to ask here then to pulg thing up with a new thread. I will ask in a new one
Craig
