buzzbomber
Thread starter- Joined
- Apr 3, 2011
- 45
Appreciate any feed back.
Since i've got the motor been out on the water with it 5-6 times. I've noticed issues trying to maintain a steady RPM rate. If I bump up the gas a little it will kind of just run away and keep increasing until I back down a bit on the throttle. Then when I back off the throttle rpms will dip until I raise the throttle up a little. (idle's great).
Not quite sure what it is or where to start. Couldnt find any other similiar posts. My guess would be remote, fuel flow, or the throttle linkage (probably not the right term). I'm not the most experience boater either so not even sure if this is normal.
more annoying than anything.
Thanks,
Buzz
Thanks,
Buzz
