1998 130 hp evinrude engine knocks
Cool Shades
I just had the carberators cleaned on my 130 hp Evinrude engine. Apparently, the carbs were really clogged so bad that the number two cylinder was not getting any fuel or very little over a couple years time. Now that the carbs are clean and the cylinder is receiving proper fuel, the cylinder has a knocking sound. Cylinder still has good compression but has a constant knock. The knock is not too loud but it is there. What could be the problem (piston, bearing, rods, what) and is it serious?
Any possible way to put additives in the fuel to make it go away?
jonesg
Re: 1998 130 hp evinrude engine knocks
Rotate the cylinder just past TDC and push down on the top of the piston with a dowel, feel any movement?
this is a johnson 175 with a bad cylinder.
It had smoke, low power and a knock, plus low compression.
http://www.youtube.com/watch?v=SgavzDPDAy0
kenmyfam
Sounds like big end or little end bearings.
Do what jonesg says and get back to us all.
