1998 150 Acceleration Issue
JP423956
Hello,
This is a 1998 offshore that I picked up to replace existing motor. Before installing I went thru the carbs. Ran it from May thru September with no issues. Then sat under a cover until this May, with treated fuel.
Issue I am having is occasional bogging on slower throttle up (not dropping the hammer) and also having a really tough time maintaining RPM between 3k and 4k when in the rough stuff. I just can't get 3,500. It will jump to 4 or drop back to 3. It's really weird.
I replaced the main fuel/water separator. Bulb stays firm. Just ordered a new inline filter. I will reverify compression this week.
The one change I did make was replace 17p aluminum with 17p stainless Mirage Plus. The aluminum would over rev. Stainless puts it right at 5,800 rpm.
Any suggestions would be much appreciated.
JP423956
Hello,
Bump... any suggested things to check?
Chris1956
Check the wiring. Maybe the jiggles cause it to lose a cylinder's spark.
