1998 3.0L Volvo Penta Mid-range RPM Engine Stumble
bergadam
I hope someone can help me, I am about fed up with this boat. I have purchased a new (not Rebuilt) 3.0L Vovlo Penta replacement engine for my 98 Glastron. I completed the first period of break in including setting the base timing to 2 degrees atdc and checked the advance which appears to be around 15 degrees btdc at 1000 rpms. Everything was fine including the idle. The Manufacturer recommends 1 hour varying rpms up to 2000 rpms. Once I went to stage two which is 1 hour up to 3000 rpms, I hit 2200 on the tach and the engine acted like it was about to die. If I give it more throttle it will kick in and get the engine up to 3000 rpms but in that range the engine runs really bad. I have checked the float level and that is good, I have also checked the accelerator pump and that seems fine(the carburetor was rebuilt last year with another issue and mistake on my part). This only happens under load. Also when I installed the new motor I did remove the outdrive (SX) and aligned the engine, which was way off and I think I got it aligned but it was still a little tight getting the alignment tool in and out plus it was a real pain putting the drive back in. Does anyone have an idea what could be the problem? I think I have tried near everything.....Thanks in advance for any help you can offer.
If initial timing is 2? ATDC: 15? BTDC, plus or minus 2?. At 2400-2800 rpm maximum
(total) advance is obtained and should be 26? BTDC (plus or minus 2?).
I don't think timing is the issue, I think your running out of fuel. Check fuel lines, filter, anti-siphon valve and then put a Vacuum/fuel pump gauge on after the fuel pump. Should be 4-7 psi
bergadam
AllDodge, you were correct, I had a spacer on my fuel pump that came with the engine kit. I removed it and the engine runs 90% better but I still have a little stumble in that range which leads me to believe now I need to fine tune the carb. I will let you know. Thanks again for your thoughts....
bergadam
Just an update to help people out, the new motor required more fuel, I upped my carb jets....problem solved
bruceb58
Honorary Supreme Mariner
I would be checking the alignment again now that you have run it awhile. Don't want to be pulling the engine for a new coupler.
