JoshKeller84
Thread starter- Joined
- Jul 2, 2010
- 220
hey guys, got the motor running great, and decided to convert to short shaft because i didnt like the way the vertical extension torque'd on the transom. ive run into a problem. I need to drop the motor another hole, but the bottom holes werent drilled to line up with the top, presumably because of a rib being in the way.
will there be any ill effects to dropping the motor down a hole, tightening the top bolts, and drilling a hole into the meat of the transom bracket on the motor, using the holes in the transom as a template? the slide hole in the bracket is at the max adjustment with the top bolts being on the 3rd highest hole.
here is a pic to show what i'm asking.. thanks! i'm talking about drilling a 1/2" hole between the slide adjustment hole and the lone hole in the middle. basically, was the entire unit cast with the holes built in, or were they drilled/milled after. thanks!
