1998 4.3 wiring scematic
dsmmace
I am looking for a tapping into a 'key switched 12v wire' and 'rpm signal' in the engine bay.
Just looking to confirm, but can I use the power signal (purple - location 9) from ignition control module for the 'key switched signal' and the tach signal wire (grey - location 11) wire off the module for rpm signal?
Don S
Re: 1998 4.3 wiring scematic
What and where are you trying to tap in?
Bt Doctur
Except for the fact you dont have O2 sensors ,it`s a waste of money
dsmmace
I have spacer plates that I bought off ebay to allow the usage of an oxygen sensor inbetween the two piece manifolds.
Here's the guy I bought them off of for future reference: http://myworld.ebay.com/ebaymotors/hotprowl/?_trksid=p4340.l2559
The only serial number I have is 0L047164.
I really hope it works. I only have those two wires left to hook up and I can attempt to fire it up.
Don S
ThaT is the correct manual.
PS: Just an FYI, That unit is not marine rated, and can be a fire/explosion hazard.
dsmmace
Isn't manual # 25 the one I need for my 4.3L?
Yes I realize that I am taking a risk and also why I put my *flamesuit* on. However with using marine fuel lines routed like a EFI marine setup and using the factory wiring for the fuel pump operation, I think I am being *smart* about it.
That being said, am I looking at tapping into the correct wiring in the engine bay? Thanks for your time so far Don, you have always given "appropriate advice" that is worth listening too.
dsmmace
I will confirm that those two wires work well for tach signal and for switched key signal. And that it runs and idles nicely so far.
dsmmace
Sorry about the crappy audio, but you get the idea.
