1998 50 HP Johnson carburetor
grassman
I took my carbs off and cleaned them out real well. Engine runs good. The only problem I am having is that once in a while when idling the engine will stall. I can either be just idling or coming from high speed. It doesn't stall all the time and starts right back up when it does. can anybody help?
HybridMX6
Re: 1998 50 HP Johnson carburetor
Sounds like idle speed is set just a tad too low. My 2000 used to do that, and I adjusted the needle on the carbs and took care of it.
grassman
it's idling about 750 rpm in the water. I backed the slow speed out on each carb 1/2 turn and it got worse, so I turned them back in. I am new at this so I guess it wouldn't hurt if someone could tell me the proper way to set the carbs
