1998 50hp carb-can't stop it from leaking
2004 searay
i have this motor its a bf50a BAZL-2000021 and have rebuilt the carb 2 times and can not stop the gas from leaking from the disc on the side . carb #2, p/n
16101-ZW4-D23​
of course this carb is no longer available. im about to through in the towel on this one, i do not know why i can't get this resolved.
can anyone give me an idea on what to do next?
jamessshelby
16101-ZW4-D23​
Had the same problem, under the disc is the vent for the carb. The carb is flooding. On my carb with bowl off and float and needle off the carb, I found a quite small piece of rubber on the needle valve seat. Removed and solved that problem.
2004 searay
i resolved the problem, i ordered and replaced everything available in side the carb and the issue cleared up
