1998 90 hp crossflow evinrude water discharge tube location.
rkmnoles
The water discharge tube from the bottom of the engine to the weep hole Has a tee in it. The tee portion of the line is broken off and I can’t figure out where of it goes. The one going to the weep hole in the bottom of the pan is intact. Any suggestions? Thanks in advance.
Honorary Supreme Mariner
Often those go to a water pressure gauge at the helm.
rkmnoles
I will check for a pressure guage. I recently picked this boat up and haven’t done much to it yet but it was quite evident when it was running.
rkmnoles
I found out this motor was a used motor put on this boat. Would it be ok to just cap it or put a single hose from the discharge to the weep hole?
