rothfm
Ensign
- Joined
- Sep 26, 2006
- 915
Racerone is correct, telltale simpily indicates the pump is spinning and supplying water to the "INITIAL" water path
The tell tale by no means indicates water is circulating at all. You can have a completely blocked powerhead and have a good pee stream.
It can be confusing unless you understand it only shows impeller output "TO" the motor.
