msd58
Thread starter- Joined
- Feb 14, 2003
- 305
My good running and reliable C90 Yamaha outboard temp alarm goes off sometimes when I run it over 4000 rpms for sustained periods. I have replaced t-stat, pop off valve, water pump and temp sensor and it still does it!!!!!! When it happens I touch motor with cover off at its warm but not hot to touch anywhere. It usually stops sounding alarm after a minute or two. Some times I shut it off other times just let it idle till it goes off. I know its the temp alarm since my motor premix. I know its the temp sensor because when I unplug the alarm wire and alarm turns off. As long as I am 3900 rpms I fine 99 % of the time.
What is the problem here?
