1998 dt150s fuel prob
dannyman3
i have a 1998 dt150s its efi and put new hosees and bulb on it the tank is a 30gal and the vent it clear the bulb goes flat at idel as well as wide open can take the cap off the tank it still does it where should i look for the trubble
99yam40
Re: 1998 dt150s fuel prob
Check valve in the bulb or anti-siphon valve at tank would be my thought.
Does your motor have a neutral switch on the motors shift linkage? And do you know what it it does to the controls as it goes in and out of neutral?
What does it affect?
dannyman3
thanks i took out the ball in the anti-siphon it seams to have worked thanks on that neutral switch i dont know but i do have a manual if you want ill read on it and get back wit ya thanks
99yam40
Thanks, if you see something about it let me know.
