FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
i got a 98 e 150 i cant get to run as i try to start it i have fuel comming out of all 6 carbs and the plugs are soaked what can be wrong and what can i do to diagnose and fix the problem????:'(
To have fuel coming out of every carb, I would say the problem is else where. All carbs' leaking would be rare. What is you starting procedure? Have you done a spark, and compression test?
Could be the primer solenoid is broke/wired wrong/turned on for rope start.Maybe tell us what happens when you try to start.Actually how do you know gas is comming out of all 6 carbs? There is (should be) a silencer covering it.What else is disconnected ?
i just bought the motor 2 weeks ago it was supposed to be completly rebuilt with zero hours i can only get it to run for a few seconds as i crank it it pours fuel out of all carbs i have the cover off at the moment the primer solenoid seems to be working the red needle is pointed down and i have spark on every plug but even they are wet with fuel????
