1998 Evinrude 35hp water temp issues!
giorgia1954
Hi, new to boating and just recently got a boat with a 1998 evinrude 35hp 3 cyl. The day we got it we took it out for a little test drive for 20 mins and it went fine no issues. Then took it out again and started up fine out on the water then within 5 mins the water temp light came on and went into SLOW mode! Then when we turned off the engine and it wouldn’t start. Then replaced thermostat and greased the prop shaft, no need for water pump because water coming out tell tale? spark plugs are all good, carbs look good. Started it up and it fired straight back up let it idle for 30 mins with hose and no water temp light issue. Took it out again and same water temp issue happened again out on the water. Again turn off engine and it doesn’t come back on. Ordered a new impeller so hopefully that will help just wondering if their could be any more possibilities or check overs we can do with this water pump issue? Thinking could be a timing sensor issue maybe, does anyone have an advice on how to test them? thank you any advice kindly appreciated asap!!! :)
giorgia1954
Also, can someone tell me if my engine has a poppet? if so where is it can’t find it for the life of me and can’t find any info on it anywhere?
Model # of your motor ?-------Temperature light ?-----Is the " mickey mouse " oil mixer still in service ?-----Or running at 50:1 mix ?-----Do a compression test first !
Sea Rider
Which is the exact Model for that 1988 motor. That's a 33 year oldie used in fresh or salt water? If it's not a water pump, t-stat related issue could be a faulty Temp Sensor issue assuming all water passages are clean and cooling the motor right when high throttle is in demand...
Happy Boating
It is said to be a 1998 model.-----They did not market the 3 cylinder 35 HP in 1988 !!!-----They generally do not have an overheat warning light.----Some models have a warning light for low oil level in the " less than reliable " oil mixer unit.
giorgia1954
Hi, thank you so much for responding. Model is e35qleca and the oil mixer has been removed.
giorgia1954
Then what's the precise model for that 1998 motor ?
Happy Boating
Hi, thanks heaps for the response, model is e35qleca and lived it’s lifetime in saltwater. I also meant to say temperature sensor not timing sensor sorry! so do you believe that being faulty could have something to do with these issues occurring? do you know how to test it to find out if it’s faulty? thank you again!
Sea Rider
Run a wot test with new impeller and T-stat installed. report if all went well, if still with same issue a matter to check/troubleshoot the Temp Sensor located on the head..
Happy Boating
giorgia1954
Happy Boating
Hi, thank you for all your help very much appreciated! New impeller should be coming in today and will fit it on and test it and get back to you! We got the temp sensor out is there a way to check it with multimeter?
giorgia1954
24 years in salt water... maybe this could help
Ah yes thank you! I was trying to look into doing a desalt of the engine, didn’t know you only needed vinegar and dish soap though, thanks so much for the helpful video!!!
Sea Rider
You're Welcome,
To troubleshoot the Temp Sensor generally needs to be Ohm tested cold and warm while being slow heated in hydraulic oil, will need the factory tech specs to test if doing its homework right or not. It's the same procedure as when troubleshooting t-stats, the only difference is one is heated with water the later with hydraulic oil.
Vinegar nor Salt Away won't do a thing with a motor run for such long years in salt water, doesn't matter if was conveniently flushed for half an hour when returning to Terra Firme. Will need a commercial discaler to remove all the salt build ups, crusts on the entire powerhead's cooling system. Seems the Temp Sensor for your model motor is NLA...
Happy Boating
