EHouseHead
Thread starter- Joined
- Sep 5, 2009
- 53
I was attempting to start my engine and after several unsuccessful tries I went to turn the key to try again and all I hear is a single "click". It sounds like it is coming from the solenoid or the starter. The batteries are charge 100%, all wiring is free of corrosion and on tight on both the batteries and the solenoid. I hooked a voltmeter up to the solenoid and we have 12V going in. I hooked the voltmeter up to the terminal/post on the starter and turned the key and it was topping out at about 6.5 Volts. Does this mean the solenoid is bad, or could it be something else? Would the starter be making any noise or attempting to do something with only 6.5 volts or would it behave as it is and do nothing at all (or just a click if it is the starter clicking not the solenoid)? Is there a way to test the starter? Can I run jumper cables from the battery to the terminal/post on the starter to see if it tries to turn?
Any input is better than none!
Thanks for your help,
DJ
DJ
