1998 Force 120 ( My Options?)
Status
Not open for further replies.
Straquan
98' Force 120
Bought the engine last April after having the compression checked. My mechanic said it was all good. He did a light tune-up, (changed plugs, cleaned carbs, got it fired up and adjusted idle) and I threw it on my 19 1/2 foot Kencraft CC. Motor needed LOTS of gas to fire up the first time out, then some days would fire right up, some days would not start at all, unless I sprayed starter fluid in the carbs. When she fired up it runs like a dream at speed and idling.
I would like to put a Yamaha 150 4-stroke on the boat but I want to wait at least until next winter until I can find one. Seems like I can't find one for a reasonable sum at the moment.
My question is....I don't mind spending money on the engine so what do you all suggest I have my mechanic do this winter? Rebuild Carbs, new impeller, plugs, what else can I have done?
Please advise...Thanks!
-Sean
kandil
Re: 1998 Force 120 ( My Options?)
Hello and welcome to iboats first you posted in the wrong forum you should post it in the force forum second never start an outboard with starter fluid it is a bad idea and last but not least an out board carb adjustment should be done in the water not at the shop and did you use the chock when you try to start it?
Status
