buzzbomber
Thread starter- Joined
- Apr 3, 2011
- 45
Sup Everyone,
Had the boat out last weekend, ran it around for about 8 hours stop and go. On the way back to the harbor with one mile to go outboard started acting up. It started running rough, started stumbling (or i guess you could say coughing or bucking). I backed it down and let it idle for a couple minutes and it seemed to sort itself out.
Got the boat back on plane for about 5 minutes then it started doing the same thing again. This time it didnt sort itself out and kept and still is running rough.
So far I've ran through all the fuel lines. They're all pretty new replaced them 2-3 months ago also rebuilt the fuel pump then to. Have been using the boat a couple times a week with no issues till now.
Here's a video of the motor and how it sounds (that deep-dull constant pop/knock sound there at idle or at speed):
http://www.youtube.com/watch?v=g1d1Li9Jw3I
So far in troubleshooting:
1. Check all hose fittings from tank to carbs all look good and even re-did a couple, bulb stays firm.
2. Check plugs bottom two cyclinder plugs seemed pretty fouled. I cleaned them but haven't had a chance to start it up again. Pic of one below:
Not sure where to go from here. Any advice on where to start troubleshooting would be appreciated. Not sure if its' a fuel or spark issue. Maybe both. I guess i'm hoping someone's heard that sound before and can point me in the right direction.
