1uz4x4
- Joined
- Jun 21, 2012
- 25
Hello,
I've been tryting to get rid of a miss that gets pretty bad around 3000rpm and up. Motor will only get up to 4850 rpm, and has a slight shake. I've bought a book and checked diodes and resistance on coils, also checked stator per instructions in book. Just tonight I found the two yellow wires from the regulator/rectifier were burnt and brown at the connectors. I fixed the connections and checked voltage at battery, 14 v at idle. I also checked it with my voltmeter by the book. I do not have a DVA meter, may have to borrow one from one of our electricions at work. Any ideas on what I need to check next. Motor is on a 21' suntracker deck boat with a 12 x 10.5 prop. Jumps out of the hole, seems to have plenty of power on the bottom end.
Thanks in advance for any help.
