1998 Force 90hp 2 stroke is it bad?
puffitu
Very happy with the 125hp I’ve got. Done pretty much everything to it; for maintenance and/or out of curiosity to it. It came on a 1990 welcraft which also got an extensive overhaul; you name it and I pretty
Much probably removed, cleaned or replaced it. The motor has never stranded me,
The Force power
I have to agree wi
I totally agree with you!! when you really get into the machines & start to understand it; they are great to have and work on.
(the proper manual is a must!!)
Sir_LR
So Shake the motor and look for discolouration and we're good right and what else should I look for???
ahicks
Regarding the motor, they can usually be fixed up to start/run really nice. Downside is, they're generally regarded as about the noisiest motor out there....
The Force power
Most likely due to the deteriorated foam insulation in the cowl.
any remaining SHOULD be removed immediately! (it will get sucked-up by the carbs.)
I replaced mine with sound-absorbing blanket material, that worked really well. On idle (only) she sounds like a 4-stroke
ahicks
I don't see many of the bigger motors, but the 40hp twins I see most never had mufflers on the carbs - which contributes a huge amount of noise. Hood insulation might help some, but an effective way of muting that carb, or carbs would be an enormous help as well....
