michelob77
Thread starter- Joined
- Nov 24, 2009
- 14
Re: 1998 Force 90hp motor flooding need HELP
I guess you meant the 828308 and I saw where it i used on the 1997 so would it be the right one that needs to be in the middle on my 1998?
Im not sure what the fuel enrichment line is but Im guessing it is the line that comes out of the small brass looking canister beside the carbs. If so there are two lines one line comes out of the canister and into the block and the other line comes out of the canister into the bowl on the top carb not middle.
I have taken some pictures of my motor setup and about to post them.
Carb P/N 838308 is the top carburetor for a 1996 - 1997 Force mercury 90HP motor. Uses the same needle valve as carbs P/N 854449, 854450 on top and bottom position on your motor.
Try removing or pinching off the fuel enrichment line going the middle carb. when you squeeze the primer bulb.
