maxhighlife
Thread starter- Joined
- May 22, 2010
- 11
i just bought a 1998 johnson 115 it has a warm running compresion readings of 90 to 100 psi across the board and will die on take off accellerator pump I assume? I will go through the carbs this weekend but should I replace the rings and hone the block before the rings break or will it just continue to ware normally it has fule pump change to run mix so no oil "should not" be and issue, Thanks
