1998 Johnson 60hp dies under more then half throttle
rdartua
Hi Guys,
Need some advice:
I own 1998 E60TLECM with what looks like a dying VRO unit.
I have disconnected oil side and pre-mix the fuel.
After moving boat to marina - all of a sudden I can no longer
go over 1/2 throttle without engine bogging down and dying.
It will work fine under 1/2 throttle. Also if you keep priming the bulb
- the engine will go to higher rpm for some time.
What do you thing - VRO fuel pump weak? Anyone had the same issue?
If this is the VRO - I want to replace it with regular pump - any recommendations on the part# for the replacement pump will be welcome.
thanks in advance for you time and input.
Robert.
rude1
Re: 1998 Johnson 60hp dies under more then half throttle
Will the primer bulb stay firm after squeezing before start up? Checked for leaks where you capped the vro or anywhere else? I think this #438559 will be the fuel pump you need but you might double check.
