turkeycreektrout
Thread starter- Joined
- Apr 19, 2008
- 16
hello all, need advice
motor is a 98 faststrike 115 v4
i changed the LU oil last summer. it was a little milky. took it to dealer and they did pressure and vacuum test and everything turned out fine. in the fall i changed it again, little milky. changed it two weeks ago and it was coffee with cream milky. no actual water drained, just the milky oil.
i guess my question is, what could be happening if the tests check out? should i just change it once a month and not worry about it? i have heard shift shaft seal or upper drive shaft seal coul be bad. does this mean water is getting in where the LU attaches to midsection? i have thought about buying a manual and learning, but i just dont know what to think, and tourney season is fast approaching. any advice would be greatful
thanks in advance
thanks in advance
