CLAMJACK61
- Joined
- May 18, 2010
- 8
Hi. New member here, I THOUGHT I posted this question earlier today...guess I forgot to hit SUBMIT after I PREVIEWED it
So...here is my situation; I purchased a 1998 Johnson 60 H.P and am in the process of removing the VRO. I am installing an older style fuel pump, like off a 1977 Evinrude 70 H.P. I am using the mounting hardware & everything bolts right up.
I have three or four of these old style pumps, as well as a few rebuild kits for them. It makes sense for me to install one. Also, I like having more open space under the cowl.
My questions are;
1. When I connect the pulse hose to this older style pump, will the PULSE LIMITER cause any operational issues? If so, can I remove the limiter & connect direct?
2.When disconnecting a VRO, most everyone leaves the unit on & use the fuel pump side of the unit. They simply plug the oil line & clip a wire (Purple?) leaving the oil pump harness plugged in to the main harness. I have totally removed it, so I have an open connector on the powerhead. I intend to cap & tape it off. Will this cause any operational issues?
If so, can I do one of the following; Cut the connector from the oil pump, plug it back in & seal each individual wire? Or, remove the oil module & plug it in, clip the purple wire, and then strap the little module off to the side.
I am also replacing all the original fuel hose with new. I went through all three carbs, all were spotless, like new.The bottom carb's float appeared saturated with oil, so I used one from a NAPA kit from the 1977 Evinrude, seems exact...is it compatible with ethanol? Are the original components in this 1998 motor also ethanol compatible, or must I upgrade?
The motor had a blown gearcase, which I replaced & also installed a new water pump, complete housing , impeller, etc. Is there ANYTHING I should be aware of on the 1998 60 H.P. " Any quirks?
Finally;
I plan to run a fuel/oil ratio of about 75:1 for normal operation, and for trolling, a separate 3 gallon tank with 100:1 to reduce smoking & fouling. Does this sound like a good course of action? Any advice, help, opinions, all are encouraged and ALL are WELCOME! thank you!!
My questions are;
Finally;
