superharmonix
Thread starter- Joined
- Sep 5, 2010
- 140
I have had this problem the last two times I took the boat out. It is a little sluggish to start cold, but always fires up and idles fine at the dock and on muffs. The motor always has fresh properly mixed fuel. (no oil pump)
After running at near WOT for 15-25 minutes, once I shut it down and fish for a few hours or longer, the motor will not fire. It cranks like normal but will not start. This is both while choking and without choking. Fresh fuel, primer bulb hard, fresh battery with tight connections and no corrosion. The first time this happened, I let it sit for a half hour or so and it still wouldn't fire. I got towed in, and a couple hours later at the dock, it started.
After that trip, I replaced the fuel line and primer bulb. This most recent trip, same scenario only this time after some time, I was finally able to get it started, but as soon as I put the throttle in neutral, it dies and will not idle. I am wondering if anyone has a similar motor with similar issues? If so, what is the fix? I really am not looking for an easy fix, as I want to know what is causing this issue so I can address it properly. Thanks in advance for any direction y'all can give.
