1998 mercruiser 5.7 Not running right
jws123
I have a 1998 mercruiser 5.7 with a 2 barrel carb on it. This boat has been sitting for 6 years so i did all the normal stuff like draining gas,replacing plugs wires ect, rebuilt carb,fuel pump, cap and rotor. My problem is it has a rough and sometimes low idle boat fires up every time but if i try to give it some gas it will stall or try to stall but once i get it past 1200 rps its fine i had it in the water for 5 hours ran good except for the ilde issue i also noticed that the tachometer jumps around sometimes not sure if it has anything to do with it but what could be causing it to run like this?
If fuel is not dripping down the carb at idle, then Sounds to me like the idle circuits are still clogged a bit. Need to try the carb rebuild again
