williamtii
- Joined
- Jun 20, 2017
- 15
Hi Everyone,
I am having trouble figuring out why the batteries are not charging on a Mercury 125hp 2+2 from around 1998. The serial number sticker is gone but from buying (and returning) parts 1998 is our best guess.
It starts, runs, and drives just fine but is not charging the batteries so after a 4hr fishing trip with multiple stop/starts they go dead. It has 2 batteries which are about 4 months old.
After doing some research a got a new Voltage Regulator and an eBay Stator which tested good on the bench (620ohms) per the figures in the link below. (40-125hp Green + White wires). I do not have the DVA leads but assume its making power since it runs fine
https://www.outboardignition.com/page39.asp
When replacing the parts I noticed the connections from Stator the Voltage regulator were pretty crusty. One broke off easily instead of unplugging so I figured I was on the right track. I replaced the bad wiring and loosened, cleaned, tightened every connection I could see.
Unfortunately the batteries are still not charging! I checked the voltage from the Regulator to the Solenoid (red wire) while running well above idle and it showed battery voltage. No changes in voltage throughout the rev range.
The only thing I notice is that I am missing approx 250-500rpm's off the top end. The Tach does not work so I am using the less than precise loud-o-meter.
Any ideas on what to check next? I would like to know it's running well before pulling it for the Winter. Thanks!
