CLi87
- Joined
- Sep 21, 2018
- 220
Hey all, i'm working on a 1998 Mercury 150 EFI and the issue is it keeps flooding out, I can get it started by holding the throttle all the way down but if I let off it'll immediately die. At first I thought it was too much oil mixing into the gas as I saw a lot of blue smoke, but I completely disconnected the oil feed line to rule that out and still the same issue just with a lot of white smoke. It seems to me the injectors are stuck open, I did an ohm test from the red wire to the other 3 and they each ohmed out at 0.9ohms. I also opened up the VST to make sure it wasn't dirty and the float wasn't sticking but it's super clean no issues, and I had just replaced the check valve at the bottom of the VST recently. Any ideas what could be causing the injectors to stick open or what to test next?
