mattisonjr
Thread starter- Joined
- Apr 12, 2015
- 16
I just picked up a 1998 14' pontoon with a 25hp motor. The boat has been sitting for 4 years, so, first thing I did was remove the carb to clean and replace gaskets. After reassembly the motor fired up pretty quickly but would bog down and smoke real bad too. The only way to get it to idle with any consistency was to turn the idle mixture screw to the fully seated position. Although it does run well, I know something can't be right because it (mixture screw} should be somewhere closer to 1-1/2 turns out. What should I be looking at to correct this problem?
