1998 Mercury Force 120 fuel issues
Tatum.david
I have a 1998 force 120 and when I prime the bulb up, fuel runs into the bottom carb from the really tiny fitting that connects the hose to the choke solenoid, when I remove that hose and plug it with my finger the bulb gets hard and no more fuel leaks. Is it possible I have those small hoses running from the bottom of the top carb incorrect or bad choke solenoid? Does anyone have a picture of the correct orientation of those small hoses
Nordin
The choke solenoid is a primer with a diaphragm inside.
Sounds like you have a hole in the diaphragm.
