1998 Regal 1700 LSR
Grunt_1021
I bought a 1998 regal 1700 lsr a while back, could never get it to run properly. ended up checking the full engine out and one piston was cracked and the block was clogged with clay so there went that. it was the omc 3.0. I found a possible 305/5.0 drive and all. a donor boat. would it be possible to swap out. would the engine fit?
Ayuh,...... Welcome Aboard,....... Anything is possible,......
It depends on how much re-engineering you want to do, 'n the talents you have to do so,.....
