1998 Tohatsu 8 hp Gearcase removal
crvantreese
This weekend when flushing my engine I noticed water a small bit of water spraying out between the driveshaft housing and the gearcase, and today I noticed a small amount of oil that has seeped out of this of the same place (See Photo). I have never noticed this before, everything runs perfect but I would like to drop the gearcase so I can see whats wrong. I refered to the service manual and they want me to remove the propeller and all attaching hardware. Is this nessesary? I have never removed the gearcase before so if I remove the 4 bolts will it simply drop down?
Thanks
Rob
TOHATSU GURU
Re: 1998 Tohatsu 8 hp Gearcase removal
It's probably just unburned fuel/oil running down the inside of the motor leg. The engine exhausts through the leg and unburned fuel/oil collects against the inside. When the engine is pulled out of the water, the water that rides there drains quickly. The petroleum residue can magically appear a day or two later. So, I wouldn't worry about it.
crvantreese
Thanks, thats good now I dont have to take it aprt
Sea Rider
Will not hurt to check if all lower LU bolts are tight....re tight if needed.
Happy Boating
crvantreese
Thanks for the reply Sea Rider, just got back in town and I checked the bolts and they are tight. I bought this boat last December and started working on it in May of this year and as you can imagine with a gas operated anything that has sat for years I have spent more time working on it than enjoying it. The motor runs perfectly now only I just noticed water spraying out between the driveshaft housing and the gearcase (please see photo). I dont know if it is mormal for this motor 1998 8hp Tohatsu (I hope it is) because I will be out on the lake this weekend instead of working on it. I apreciate any help you or anyone els can give me on this.
pvanv
That's a drain to let the water out to prevent freezing issues. No problem.
crvantreese
Thanks Paul, Obviously I'm new to this I just could not find anything in the owners manual or the service manual that talked about it. You have made my day and weekend, although I'm almost sad that I have nothing else to fix, repair, or replace; everything is perfect now.
