mitchellz71
Thread starter- Joined
- Dec 28, 2009
- 25
I have a 1998 Venom 225HP that I am having some issues with. Sometimes it will bog down really bad when I punch it from idle. If I hold it at WOT from idle it will usually die, but if I back out of the throttle and then slowly engage the throttle the engine will slowly pick up and then be fine. Also it will sputter and die if it idles for an extended period. Other than these issues the engine runs great. I replaced the VRO pump because my mechanic said it was about to go out, and I was hoping that would solve the problem, but it did not.
So where should I start to look for problems? My mechanic also suggested a carb clean which would run me 800-900 dollars, so I may try to do that myself, is it a tough job?
Thanks,
Petty
Thanks,
Petty
