StPeteBoater123
Thread starter- Joined
- Aug 28, 2016
- 8
Hello All,
OK I am at my wits end here. Here is the boat/motor and the issue:
Boat/Motor
1998 - 19 foot Cobia
1998 - 2-Stroke Yamaha 115HP
Issue:
I've always had a slight "problem" with the motor turning over easily after I haven't been using it (I'm talking about a day or two, not months). It just takes a little longer.
Currently (within the last month) the new issue is that when i turn the ignition key, nothing happens. Then I will wait a second and then try again and then nothing will happen usually for 5 seconds, then the motor tries to start. Same thing over and over as the second part, the more I try the less the pauses seem to be.
USUALLY it will actually eventually turn over and then runs perfect. If I was to turn off the engine, it usually starts back up no problem. Recently that has not been the case though.
What I have done already:
- Cleaned all connections with baking soda and a wire brush
- Charged both batteries (my starting battery and deep cycle) via AutoZone who said the starter battery was very weak but still good
- STILL Bought a new starter battery just to see if that was it (because after I charged the battery i still had the issue) - got the same issue
- Now I'm onto the good old multimeter to find an issue...
I am NOT that handy when it comes to this stuff so please pardon my ignorance if I did something wrong taking the readings... Here is a pic to show what I came up with after going through hours of threads on starting issues....
Each arrow represents where I connected the leads from the multimeter to. All the red arrows came back at 12.5. The yellow arrow gave me nothing.... is that supposed to happen?
ANY input would be appreciated since currently I can't get anything to happen. I turn the key (my gauges light up and flicker) and no click from the solenoid and no turning over.
IDEAS?! Thanks so much everyone
Boat/Motor
Issue:
