draft raft
Thread starter- Joined
- May 25, 2008
- 22
I have a 1999 115 hp Johnson motor on my 99 four winns, the problem is when it's first started,It runs extremely rough, and misses to beat the band! "Once in a great while" I might hear a muffed (backfire??) and the engine stalls. It starts right up again, but continues to run rough. If I increase thorttle a little, it smooths out, to just a little better. Once I get to the lake, I drop the trim,start to plane, NO PROBLEM, run it at WOT, again NO PROBLEM. After a spin around the lake and pull into the swim hole, it runs fine, when I bring it down to a slow idle/wake, slight missing, but will stay running. After a couple of hours at the swim hole, I start it, starts right up, but again runs really rough, and even sometimes stalls.....are the Johnson motors just warm running motors?? I am the second owner(first was a very old couple that hardly ever drove it), but I've had it 5 years now, and I myself am told by the local marina that the motor only has appox. 160 hours on it(extremely low for a 99) And they were shocked to say the least, because last year I had to put out the money for a new water pump...(wasn't peeing any more,...impellers fins were all bent permanently over,inside the water pump, but it's all good now). If I'm pulling a skier/tuber, and have to shut off in the middle of the lake to change people, starts right up, idles just fine, takes off and runs perfect. Again the rough idle and stalling problem seems to be when the motors cold, or not warmed up yet at a low rpm. Any advice would be helpful. Thank you very much in advance, Draft
