1999 175 fast strike dies when shifting from fwd to reverse
bignefan
hey guys,just need a little help I have twins so finding problem is some times easier cause I can switch parts back and forth to see if something is messing up.I thing the problem is the little box that the shift cable pushes I think it called shift interrupt switch but I can find it on any schemadic or apart #.Can anyone help me out model #J175pxees
Joe Reeves
Re: 1999 175 fast strike dies when shifting from fwd to reverse
Yes, that's what the shift switch is called. It's purpose, when shifting out of gear, is to knock out the ignition on the starboard bank momentarily to enable the shifter dog to disengage from whatever gear it might be in. So short an interruption that normally it is never noticed.
To test to see if it is that switch which is causing the problem, simply follow the black/yellow wire from that switch back to its connector and disconnect it. If that cures the problem, either the switch is defective or (and most likely) there is a salt corrosion or tightness of some kind at the nylon bushings that the engine's shift linkage goes thru (just the other side of that switch), causing a binding of the linkage.
If no change in the problem..... first, check compression (what are the readings?), then check the spark (with all spark plugs removed) which should jump a 7/16" gap with a strong blue lightning like flame. Does it?
Do all the spark plugs look the same?
daselbee
On shop.evinrude.com, drill down to your motor, and on the Cylinder and Crankcase page, it is reference # 76, PN 585013.
Easily tested by just unplugging it to see if your problem goes away.
bignefan
Thanks guys
Joe your the man,it is the shift interupt.While the cover is off I'll replace the nylon bushings
Daselbee thank for the #'s you guys are great
Joe Reeves
Keeps us smiling just to know that every once in a while, we're able to help someone.
