Tommy Hobbs
- Joined
- May 15, 2005
- 5
This problem does not happen every time that I run this motor and it always seems to happen when I am going upstream in the river never downstream. I will be running along at 85 TO 100% WOT and the engine will all at once drop to about 30% TO 40% power. It seems to be running smoothly but sounds as if under load and if cut back to idle it may run smoothly or it may skip. I can switch it off and wait 30 minutes or so and then it is normally alright for awhile. I was wondering if it might be a coil shorting out. Any info would be greatly appreciated<br /><br />Thanks,
