Searsnathan81
Thread starter- Joined
- Jul 27, 2021
- 13
I’m currently have an issue with the fuel pump relay not getting power to the fuel pumps(high and low pressure). I have checked the relays but am not getting the proper ground from the wire that goes from the ecm to the relay. As a quick fix I have resulted in taking power from the ignition switch to the fuel pumps resulting in both fuel pumps running when the ignition is in the on position. I plan on getting the ecm tested once the season is over. Does anyone see an I issue running the boat like this Atleast till I get the ecm tested after the season is over?
Thanks
Thanks
