1999 90 Looper weak spark
Rogue I
Hi gang,
Issue with my 90 Johnson any insight greatly appreciated!!
Carbs were gone through and cleaned out along with new gaskets this winter. Tach was dead so I swapped rectifiers (had another used but good one) and tach functionality has returned. Pulled compression a month ago (do it every spring) and it was 120psi on all 4.
When I fired her up a month ago and idled her on the hose I thought all 4 holes were firing. However, this weekend when I cranked the motor it sounded a bit off. On the hose, I pulled the plug wires one-by-one. 3 of the 4 plug wires, when pulled caused a major RPM drop / near stall. 4th (top stbd) wire when pulled causes no change.
I don't have a spark tester however I did pull the plug and wire and had my son crank as I held the plug against engine ground and I'm getting some spark. That plug also shocked me through the boot (not sure if arcing??).
Tried swapping coils -- no change.
Tried swapping plug wires -- no change.
Tried swapping plugs -- no change.
Motor has only idled on the hose a few times since a month ago when I pulled compression. I can't imagine I somehow lost compression / blew the hole? But I will re-check (don't have a gauge will have to borrow). Also skeptical it's starving for fuel but I can go through that cylinder's carb again and check -- do these carbs cross-feed (ie, top stbd cylinder fed by top port carb)?
Stbd tan temp wire is somewhat close to coil wire however I can't re-route it further away without cutting/splicing it and while I don't make a habit of winding a motor up on the hose it will rev past 2500 so not thinking this is a SLOW issue. But I could be wrong?
My question is, can weak / intermittent spark cause a situation where I am getting some spark but not enough to efficiently produce power in a cylinder? Has anyone ever seen something like this? If so, is a bad pack more likely than a bad stator? I don't have a DVA.
Any other ideas? Thank you!!
You might give us a model number so we know exactly what ign system you have. When you say you swapped rectifiers, do you really mean you swapped water cooled voltage regulators?
Rogue I
No Title
Any ideas? Plug in dead cylinder appears to be getting fuel. Re-checked compression 125-130PSI all 4. Pulled flywheel and stator shows no brown goo or burnt windings. Non-firing cylinder shows coked piston so I am not thinking this is a water intrusion issue.
Seems that leaves the powerpack? Can a dirty/bad optical eye cause these issues? Has anyone ever seen a stator go bad without showing physical signs (burnt brown goo etc)?
Thank you for any help.
PS. removing that plastic timing wheel was impossible without breaking it ... ordered a new one but bad design.
