aquaholicjavi
Thread starter- Joined
- Feb 2, 2010
- 7
I have a 99 90HP johnson that its starting to bog down when I begin to accelerate it out of idle. At times I have to do it very slowly and at other times it just dies on me. When the engine is on idle it seems to be runing smooth, and when I get past that initial acceleration it runs fine at top speed too. The problem seems to be happening just to get out of idle. Everytime I take the boat out I feel that the problem is getting worse.
I cleaned all four of my carbs this weekend and set the carb adjustments to 5 3/4 turns from lightly seated. Any other ideas on what could be causing this? Should I play with the needle adjustments on the carbs?
Thank you
Javier
Thank you
Javier
