TEXAS ROD WORKS
Thread starter- Joined
- May 23, 2008
- 29
I bought a new boat that has a 1999 90hp on it , motor runs great ,when you run it wide open it will go bought 500yds and then act fuel starved. the guy that had it before me put a 5psi priming pump in line between the fuel filter and the tank. I have changed the vro pump and also bipassed the filter and 5psi pump and went from the tank to the motor ,still does it. the boat idles well . what do i check now? also if i turn the 5 psi pump on it will run and never act fuel starved.
