FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
the bearing caps are pressed into the yoke and should be a tight fit. If the cap is loose the yoke or inputshaft needs replacing . If you mean slop in the U joint cross, then replace the U joints
upon closer inspection, the locknut was loose and the bevel washer had excessive wear on the u joint assembly Everything else looked good on the upper end.
Waiting on the part, hope that is all that's needed
