1999 Evinrude 175 Ficht tough to start after stopping for 10+ minutes
bassin89
I also noticed that the head on the port side is getting pretty hot whereas the starboard head is staying relatively cool.
bassin89
Looks like I've got a bad thermostat on the port side, could that be what os overheating the EMM when the engine is turned off?
bassin89
*Update*
Because of the primer bulb not getting hard I decided to check the fuel lift pump. I pulled the lines from it, one going to the #2 cylinder and one to the #6, and pumped the primer bulb. Fuel came out of the #2 line, this isn't supposed to happen is it?
bassin89
Could fuel from this be leaking down into the cylinder and causing the hard start issue after sitting for 20 or more minutes that I am having?
