Just purchased a 1999 Force 120hp outboard with a 25" lower unit. I'm looking for the list for converting it to a 20" by removing the 5" spacer below the drive shaft housing. As I see it based on parts microfiche I will need a compriable spline 20" shaft, a 20" shift shaft, a 20# water inlet tube, standard shorter housing bolts/studs and a gasket set for lower unit. I'm trying to buy the primary parts via ebay and am running into some part# issues. Can any one tell me if an F694128 or 45-F694128 will work for the 1999 20" shaft? Thank you for your response...I'm having a merc marine dealer do the work...I need to aquire the bigger purchase parts. Any help with the parts list would be appreciated. Please no shoot off the hip answers as I am in the process of shopping up hard parts. Thank You! cassabby
