1999 force carb problem need help plese
littlejo
hey new here i have a 120 force and it is running rich like to is fluding out i cleand the carbs and set the floots it is flowing fuel up out of the carb still i have opend them up like 5 times now still cant find anything like i said it is running out the carb and if i tip the motor up it realy comes out bad but on the water runs good aslong as i dont let it idal long its like it just fluds out
further
Re: 1999 force carb problem need help plese
Just from what i've picked up on over the past week or so this may be caused by the floats not being properly adjusted. When you turn the carb upside down the float should sit parallel with the carb body. When it is turned right side up the float should hang down to the point just before it hits the main jet. If they are not set right they need to be adjusted.
foodfisher
Sounds like the needles aren't seating properly. While adjusting floats, blow through the fuel line in the direction of fuel flow and see if the needles stop the airflow when carb is upside down.
littlejo
i did all that and it still is flowing fuel out the front of the carb not as bad but still makes it run like crap on low end spit and sputter not sure what to do
foodfisher
Bad carbs? Carbs are just parts. If you did what has been suggested, slow and steady with no short cuts, they have to work. It is in God's hands or Frank"s otherwise.
