1999 jhonson 115 model j115pleem 3 questions ?
dkm630
how u know if u have v4 foot or v6 foot when looking for prop it ask u 13 or 15 spline gear case ? also tach is stuck on 200 rpm weather motor is on or off , also temp gauge not working needle does not move any help on this to fix
be apprecaited , thx.
Chris1956
Re: 1999 jhonson 115 model j115pleem 3 questions ?
Count the splines on the prop shaft. Also V6 gearcases are 4-3/4" wide at the rear.
It sounds like your tach is either bad or the wiring is not making a good connection somewhere. Does the motor charge the battery?
Ditto on the temp gauge. Ground the temp sender wire at the motor and see if the gauge moves. If not find the break in the wiring, of find out why it is not getting +12VDC or Ground.
bob johnson
just know if you got to count the splines, youll have to take your present prop off first!!!
the V4 is a tad over 4"
so not a good eye ball difference...you should use a tape measure.
the splines is the easiest check
as for the guages, have they ever worked while have owned and used the boat??
bob
dkm630
yes all was working , boat set up 1yr now not working engine runs awsome , volt gauge reads 12 to 15 volts depending how fast going ,thx for the dia. on foot , for as tach and temp gauge it has 12 volts behind it, but i will double check , for as temp do u check ground with key on or off ? thx for all the help.
