1999 Johnson 130hp flywhel nut removal???
thyNemesis
Hello,
I'm about to remove my flywheel and wanted to know if this nut is left hand or right hand?
The nut size is 1-7/16 and the screws for the puller is 5/16-24 threads, just in case someone needed that information.
I had to purchase a 1-7/16 socket and turn down the outside a few thousands just to fit into the recess area where the nut is located. What a pain in the...
Is there any safety concern with removing this nut, i.e. engine kicking while I try and spin this nut off? I have the power disconnected, any other safety concerns I should look out for???
Thanks.
Will Bark
Re: 1999 Johnson 130hp flywhel nut removal???
Lefty ,loosey is the way to go; you will need to find some way to hold the flywheel while you loosen the nut. Most use a flywheel wrench, others use a strap and others just stick a big screwdriver between teeth of flywheel and engine block. In any case be patient and use grade 8 bolts on your puller. Good luck
boobie
You can also use an impact driver if you have access to one of them. Also disconnect the spark plug wires.
thyNemesis
Thanks.
Got it removed without issues.
