thyNemesis
Thread starter- Joined
- Apr 19, 2013
- 73
I'm having some fuel delivery issues and I'm at a loss of where to starting looking again.
The boat had been running for quite sometime without issue. One day I ran out the channel, about 2.5 miles out or so, did some fishing and started to head back in. The motor started up and I ran for a few minutes up on plane, all of a sudden, engine started to die. I pumped up the fuel bulb and started the engine again, came up on plane for a few minutes and engine dies again. I had to do this over and over again all the way back in. However, while running the no-wake zone, about 15 minutes or so, boat would idle all the way back in without shutting down.
So far I have replaced the primer bulb, installed new fuel line from fuel pump all the way back to the water seperator with new clamps. New in-line fuel filter, replaced the Water seperator filter, installed a new check valve on top of the pick-up tube, blew out the pick-up tube with compressed air, 10-15 psi.
Any other ideas I'm missing? Am I in the right area, i.e. fuel supply, from tank to fuel pump?
Could it be my fuel pump? Any way to test the fuel pump prior to re-building it myself?
Thanks
Jeff
Thanks
Jeff
